8GB SDHC CARD PROBLEM
sukhi-2006
I have a 8Gb sdhc card, I have vista home premium os which doesn't recognise it, in my computer it should come with k drive but that doesn't appear, how can i make my sdhc card work.
i have card reader which only uses sd card it doesn't even work with that.
Do you have access to another PC with another card reader? Does the card work with any SDHC compliant devices?
I have a sd card reader built in my pc, it doesn't work i think it's only made for sd cards, can anyone give me link for built in sdhc card reader.
If you have Vista on it, I doubt that it doesn't support SDHC. Do SD cards work in it?
Also on Vista bashing: Do you expect him to drop his evil Windows using ways and pick up Ubuntu or something? Do you want him here or anywhere else asking 100 questions for things he already knows how to do in Vista?
I'm using Vista by the way, and I don't have ANY issues with it.
E8200 from 2.66 @ 3.6ghz
Radeon HD 4850
4GB DDR2 1000
$650 total cost
Stalker: Clear Sky enhanced DX10 maximum settings @ 30FPS:
http://i33.tinypic.com/29dvjva.jpg
http://i38.tinypic.com/2zzm1xh.jpg
My sdhc card worked in gp2x f-200 console and i used that with my vista computer, the gp2x was compatible with sdhc cards upto 32gb.
I don't have the gp2x anymore because it broke down, so i can't test it anymore apart from my xp computer well i don't use that computer anymore.
I want to use this card on the pandora console.
Had some weird problems myself with vista and SDHC cards, had a card reader that would read SDHC using a virtual XP installation running as a guest OS under Vista but would not read SDHC under vista despite all updates and related Knowledge base suggestions being applied and tried.
My solution was to buy a new card reader for £6 , it worked fine.
This is the one I went for : http://www.ebuyer.com/product/108453
the pandroa will be able to link directly to the pc, for such problems
so you just put you sdhc card into the pandora, hook the pandora up to the pc and it should appear
