Neelix
Insecticidal Maniac
I'm running SuperZaxxon 1.53. (all current upgrades have been applied)
I've noticed that the first time I enable WiFi (using the config button menu) after booting the WiFi LED does not light up. (though the WiFi itself does work)
Once it has been enabled and disabled for the first time, it will work normally for subsequent uses of the WiFi toggle.
If I enable WiFi for the first time after boot from the terminal, the LED *does* light up, but I see the following set of errors appear:
op-vizzini:~$ sudo /usr/pandora/scripts/op_wifi.sh
Starting WL1251 MAC80211 Wireless LAN driver: wl1251.
op-vizzini:~$ find: /lib/modules/3.2.30/updates: No such file or directory
Usage: insmod filename [args]
ERROR: Module board_omap3pandora_wifi does not exist in /proc/modules
op-vizzini:~$
I notice the errors appear after the script completes, but again, only with the first execution.
This happens consistently with every boot. Is anyone else seeing anything like this?
- Neelix
op-vizzini:~$
- Neelix
