I just got my GP2X, and decided to try it out. So I stuck in an SD card that I had from my (now broken) Palm, and the GP2X played several songs. Great.
Then I tried to connect it with the USB cable to my Windows XP Home SP2 computer. Windows finds the device ("File-backed storage gadget" or something similar), decides what it is ("USB Mass Storage Device"), and then tells me that there was a problem installing the device. When I go into the device manager, the device is marked with a warning symbol and details say "This device cannot start. (Code 10)".
I get the same message on two other computers, so I don't think the problem is the computer hardware (though it could be the OS, but others seem to have it working). I tried a different cable (same plug) that came with the Palm, but got the same error, so I think it's not the cable. I can access the music on the SD card, so I don't think the problem lies with the SD card or it's formatting (though the USB connection could be using a different method of accessing the card).
Another possible hint to the problem is that even after I close the USB connection on the GP2X, the GP2X freezes as soon as I unplug the cable.
So, does anybody have any ideas on what I should try doing? I'm at a loss to come up with anything.
Thanks in advance,
A Schmitz
Thanks in advance,
A Schmitz
