skeezix
Internal Development
I'm getting a lot of questions over this one still --
When charging, _yes_, the Pandora will be on (many devices are like this; they often show a different screen while powering, but are still 'on', if in lesser-functional-mode; we don't have that in the Pandora firmware yet, it just goes 'full on' while charging, from an off-state.)
When charging, you can still go to low power mode!
Low power mode is when you do a quick hit to the power slider-switch; the device will appear to go 'off'-ish; screen will turn off, wireless network will drop off, the CPU speed goes to a minimal amount; your batteries will go a long time in this mode, and when charging, you will charge up much faster since very little is being drained from the battery. (Normally, in full power mode while charging, the Pandora is drawing from the battery while the battery is also being charged, hence low power mode allows more overall charging to occur.)
Closing the device lid is not low power mode; that is 'screen off' mode, since you might be doing streaming audio, or playing mp3s, or whatever.
So, to charge fastest:
1) Be sure to be patched up with latest hotfixes or firmware version
2) Plug in the pandora; if not already on, it will turn on and boot up.
3) Hit the power switch to go to low power mode
4) Close the lid if you like. * on older hotfixes, closing lid and low power mode at the same time made things a little wonky, but should be okay now.
jeff
jeff
