Hi, I had tried deleting the whole list before I reflashed, but sadly to no avail:-(
Here is the dmesg thing, I hope this lot means something to you guys.
kevin-openpandora:~/Desktop$ dmesg
tyS0 at MMIO 0x49020000 (irq = 74) is a ST16654
[ 10.087829] console [ttyS0] enabled
[ 10.532714] brd: module loaded
[ 10.538085] loop: module loaded
[ 10.541442] set_opp: OPP 3 set
[ 10.544586] pndctrl loaded.
[ 10.547515] usbcore: registered new interface driver asix
[ 10.553070] usbcore: registered new interface driver cdc_ether
[ 10.559051] usbcore: registered new interface driver rndis_host
[ 10.565032] i2c /dev entries driver
[ 10.569610] input: power-button as /devices/virtual/input/input0
[ 10.597320] triton2 power button driver initialized
[ 10.603363] Driver 'sd' needs updating - please use bus_type methods
[ 10.609985] omap2-nand driver initializing
[ 10.615264] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xbc (Micron NAND 512MiB 1,8V 16-bit)
[ 10.624420] cmdlinepart partition parsing not available
[ 10.629730] Creating 5 MTD partitions on "omap2-nand":
[ 10.634887] 0x00000000-0x00080000 : "xloader"
[ 10.639862] 0x00080000-0x00260000 : "uboot"
[ 10.645080] 0x00260000-0x00280000 : "uboot-env"
[ 10.649902] 0x00280000-0x00c80000 : "boot"
[ 10.658477] 0x00c80000-0x20000000 : "rootfs"
[ 10.873260] UBI: attaching mtd4 to ubi0
[ 10.877105] UBI: physical eraseblock size: 131072 bytes (128 KiB)
[ 10.883453] UBI: logical eraseblock size: 129024 bytes
[ 10.888916] UBI: smallest flash I/O unit: 2048
[ 10.893646] UBI: sub-page size: 512
[ 10.898315] UBI: VID header offset: 512 (aligned 512)
[ 10.904205] UBI: data offset: 2048
[ 12.163818] UBI: attached mtd4 to ubi0
[ 12.167663] UBI: MTD device name: "rootfs"
[ 12.172760] UBI: MTD device size: 499 MiB
[ 12.177764] UBI: number of good PEBs: 3992
[ 12.182495] UBI: number of bad PEBs: 4
[ 12.186981] UBI: max. allowed volumes: 128
[ 12.191650] UBI: wear-leveling threshold: 4096
[ 12.196380] UBI: number of internal volumes: 1
[ 12.200866] UBI: number of user volumes: 1
[ 12.205352] UBI: available PEBs: 0
[ 12.209838] UBI: total number of reserved PEBs: 3992
[ 12.214843] UBI: number of PEBs reserved for bad PEB handling: 39
[ 12.220977] UBI: max/mean erase counter: 7/1
[ 12.225280] UBI: image sequence number: 978767716
[ 12.230072] UBI: attaching mtd3 to ubi1
[ 12.233947] UBI: physical eraseblock size: 131072 bytes (128 KiB)
[ 12.240264] UBI: logical eraseblock size: 129024 bytes
[ 12.245727] UBI: smallest flash I/O unit: 2048
[ 12.250457] UBI: sub-page size: 512
[ 12.255126] UBI: VID header offset: 512 (aligned 512)
[ 12.260986] UBI: data offset: 2048
[ 12.267822] UBI: background thread "ubi_bgt0d" started, PID 29
[ 12.310577] UBI: attached mtd3 to ubi1
[ 12.314361] UBI: MTD device name: "boot"
[ 12.319335] UBI: MTD device size: 10 MiB
[ 12.324249] UBI: number of good PEBs: 80
[ 12.328826] UBI: number of bad PEBs: 0
[ 12.333312] UBI: max. allowed volumes: 128
[ 12.337951] UBI: wear-leveling threshold: 4096
[ 12.342712] UBI: number of internal volumes: 1
[ 12.347198] UBI: number of user volumes: 1
[ 12.351654] UBI: available PEBs: 0
[ 12.356140] UBI: total number of reserved PEBs: 80
[ 12.360961] UBI: number of PEBs reserved for bad PEB handling: 2
[ 12.367034] UBI: max/mean erase counter: 18/8
[ 12.371429] UBI: image sequence number: 328488659
[ 12.376190] usbmon: debugfs is not available
[ 12.380889] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 12.386871] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
[ 12.394683] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 12.400421] UBI: background thread "ubi_bgt1d" started, PID 30
[ 12.409606] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
[ 12.417602] usb usb1: configuration #1 chosen from 1 choice
[ 12.423400] hub 1-0:1.0: USB hub found
[ 12.427276] hub 1-0:1.0: 3 ports detected
[ 12.535308] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 12.542144] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 12.549438] usb usb1: Product: OMAP-EHCI Host Controller
[ 12.554809] usb usb1: Manufacturer: Linux 2.6.27.46-omap1 ehci_hcd
[ 12.561065] usb usb1: SerialNumber: ehci-omap.0
[ 12.565704] Initializing USB Mass Storage driver...
[ 12.570770] usbcore: registered new interface driver usb-storage
[ 12.576843] USB Mass Storage support registered.
[ 12.581634] usbcore: registered new interface driver libusual
[ 12.587646] mice: PS/2 mouse device common for all mice
[ 12.613494] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[ 12.683654] input: keypad as /devices/platform/i2c_omap.1/i2c-adapter/i2c-1/1-004a/twl4030_keypad/input/input2
[ 12.739288] input: nub0 as /devices/platform/i2c_omap.3/i2c-adapter/i2c-3/3-0066/input/input3
[ 12.792938] input: nub1 as /devices/platform/i2c_omap.3/i2c-adapter/i2c-3/3-0067/input/input4
[ 12.847686] twl4030_rtc twl4030_rtc: rtc core: registered twl4030_rtc as rtc0
[ 12.858032] bq27x00-battery 3-0055: support ver. 1.1.0 enabled
[ 12.864013] Bluetooth: HCI UART driver ver 2.2
[ 12.868499] Bluetooth: HCI H4 protocol initialized
[ 12.873352] Bluetooth: HCILL protocol initialized
[ 12.878143] hci_h4p hci_h4p: Registering HCI H4P device
[ 13.112762] hci_h4p hci_h4p: No cts from bt chip
[ 13.117462] hci_h4p: probe of hci_h4p failed with error -110
[ 13.123504] mmci-omap mmci-omap.0: Failed to get debounce clock
[ 13.230072] mmci-omap mmci-omap.1: Failed to get debounce clock
[ 13.231231] mmci-omap mmci-omap.2: Failed to get debounce clock
[ 13.231597] Registered led device: pandora::sd1
[ 13.236267] Registered led device: pandora::sd2
[ 13.240997] Registered led device: pandora::bluetooth
[ 13.246185] Registered led device: pandora::wifi
[ 13.251159] Registered led device: pandora::keypad_bl
[ 13.256469] Registered led device: pandora:
ower
[ 13.261566] Registered led device: pandora::charger
[ 13.266662] usbcore: registered new interface driver usbhid
[ 13.272338] usbhid: v2.6:USB HID core driver
[ 13.276855] Advanced Linux Sound Architecture Driver Version 1.0.17.
[ 13.283477] ASoC version 0.13.2
[ 13.286804] OMAP3 Pandora SoC init
[ 13.290374] TWL4030 Audio Codec init
[ 13.295623] asoc: twl4030 <-> omap-mcbsp-dai-0 mapping ok
[ 13.302551] asoc: twl4030 <-> omap-mcbsp-dai-1 mapping ok
[ 13.315582] ALSA device list:
[ 13.318634] #0: omap3pandora (twl4030)
[ 13.322845] TCP cubic registered
[ 13.326141] NET: Registered protocol family 17
[ 13.330657] NET: Registered protocol family 15
[ 13.335174] Bluetooth: L2CAP ver 2.11
[ 13.338867] Bluetooth: L2CAP socket layer initialized
[ 13.343994] Bluetooth: SCO (Voice Link) ver 0.6
[ 13.348571] Bluetooth: SCO socket layer initialized
[ 13.353668] Bluetooth: RFCOMM socket layer initialized
[ 13.358917] Bluetooth: RFCOMM TTY layer initialized
[ 13.363861] Bluetooth: RFCOMM ver 1.10
[ 13.367645] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 13.373016] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 13.379516] RPC: Registered udp transport module.
[ 13.384246] RPC: Registered tcp transport module.
[ 13.389099] ThumbEE CPU extension supported.
[ 13.393402] Disabling unused clock "sr2_fck"
[ 13.393402] Disabling unused clock "sr1_fck"
[ 13.393432] Disabling unused clock "mcbsp_fck"
[ 13.393463] Disabling unused clock "mcbsp_fck"
[ 13.393463] Disabling unused clock "mcbsp_ick"
[ 13.393493] Disabling unused clock "mcbsp_ick"
[ 13.393524] Disabling unused clock "gpt2_ick"
[ 13.393524] Disabling unused clock "gpt3_ick"
[ 13.393554] Disabling unused clock "gpt4_ick"
[ 13.393554] Disabling unused clock "gpt5_ick"
[ 13.393554] Disabling unused clock "gpt6_ick"
[ 13.393585] Disabling unused clock "gpt7_ick"
[ 13.393585] Disabling unused clock "gpt8_ick"
[ 13.393615] Disabling unused clock "gpt9_ick"
[ 13.393615] Disabling unused clock "wdt3_ick"
[ 13.393646] Disabling unused clock "wdt3_fck"
[ 13.393646] Disabling unused clock "gpio2_dbck"
[ 13.393676] Disabling unused clock "gpio3_dbck"
[ 13.393676] Disabling unused clock "gpio5_dbck"
[ 13.393707] Disabling unused clock "gpt9_fck"
[ 13.393707] Disabling unused clock "gpt8_fck"
[ 13.393737] Disabling unused clock "gpt7_fck"
[ 13.393737] Disabling unused clock "gpt6_fck"
[ 13.393737] Disabling unused clock "gpt5_fck"
[ 13.393768] Disabling unused clock "gpt4_fck"
[ 13.393768] Disabling unused clock "gpt3_fck"
[ 13.393798] Disabling unused clock "gpt2_fck"
[ 13.393798] Disabling unused clock "gpt1_ick"
[ 13.393829] Disabling unused clock "wdt1_ick"
[ 13.393829] Disabling unused clock "wdt2_ick"
[ 13.393859] Disabling unused clock "wdt2_fck"
[ 13.393859] Disabling unused clock "gpio1_dbck"
[ 13.393890] Disabling unused clock "gpt1_fck"
[ 13.393890] Disabling unused clock "cam_ick"
[ 13.393920] Disabling unused clock "cam_mclk"
[ 13.393920] Disabling unused clock "des1_ick"
[ 13.393951] Disabling unused clock "sha11_ick"
[ 13.393951] Disabling unused clock "rng_ick"
[ 13.393981] Disabling unused clock "aes1_ick"
[ 13.393981] Disabling unused clock "ssi_ick"
[ 13.393981] Disabling unused clock "mailboxes_ick"
[ 13.394012] Disabling unused clock "mcbsp_ick"
[ 13.394073] Disabling unused clock "gpt10_ick"
[ 13.394073] Disabling unused clock "gpt11_ick"
[ 13.394104] Disabling unused clock "uart2_ick"
[ 13.394104] Disabling unused clock "i2c_ick"
[ 13.394134] Disabling unused clock "hdq_ick"
[ 13.394134] Disabling unused clock "mspro_ick"
[ 13.394165] Disabling unused clock "des2_ick"
[ 13.394165] Disabling unused clock "sha12_ick"
[ 13.394165] Disabling unused clock "aes2_ick"
[ 13.394195] Disabling unused clock "icr_ick"
[ 13.394195] Disabling unused clock "pka_ick"
[ 13.394226] Disabling unused clock "ssi_ssr_fck"
[ 13.394226] Disabling unused clock "hdq_fck"
[ 13.394256] Disabling unused clock "uart2_fck"
[ 13.394256] Disabling unused clock "mcbsp_fck"
[ 13.394287] Disabling unused clock "mcbsp_fck"
[ 13.394287] Disabling unused clock "i2c_fck"
[ 13.394287] Disabling unused clock "mspro_fck"
[ 13.394317] Disabling unused clock "gpt11_fck"
[ 13.394317] Disabling unused clock "gpt10_fck"
[ 13.394348] Disabling unused clock "iva2_ck"
[ 13.394348] Disabling unused clock "dpll4_m6x2_ck"
[ 13.394378] Disabling unused clock "dpll4_m5x2_ck"
[ 13.394409] Disabling unused clock "dpll3_m3x2_ck"
[ 13.394409] Disabling unused clock "sys_clkout1"
[ 13.394439] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1
[ 13.433532] Console: switching to colour frame buffer device 100x30
[ 13.526977] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 13.535156] mmc0: new high speed SDHC card at address 8520
[ 13.541076] mmcblk0: mmc0:8520 SD16G 15859712KiB
[ 13.546112] mmcblk0: p1
[ 13.622833] twl4030_rtc twl4030_rtc: setting system clock to 2011-03-29 20:24:19 UTC (1301430259)
[ 13.742553] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[ 13.748687] UBIFS: file system size: 508096512 bytes (496188 KiB, 484 MiB, 3938 LEBs)
[ 13.756774] UBIFS: journal size: 9033728 bytes (8822 KiB, 8 MiB, 71 LEBs)
[ 13.764160] UBIFS: media format: w4/r0 (latest is w4/r0)
[ 13.770050] UBIFS: default compressor: lzo
[ 13.774169] UBIFS: reserved for root: 0 bytes (0 KiB)
[ 13.780639] VFS: Mounted root (ubifs filesystem).
[ 13.785552] Freeing init memory: 148K
[ 14.089172] mmc1: host does not support reading read-only switch. assuming write-enable.
[ 14.097442] mmc1: new SDHC card at address b1f8
[ 14.102447] mmcblk1: mmc1:b1f8 SD16G 15558144KiB
[ 14.107513] mmcblk1: p1
[ 14.998138] udev: starting version 151
[ 16.058380] ads7846 spi1.0: touchscreen, irq 254
[ 16.063629] input: touchscreen as /devices/platform/omap2_mcspi.1/spi1.0/input/input5
[ 21.450653] NET: Registered protocol family 10
[ 21.487457] FAT: bogus number of reserved sectors
[ 21.492279] VFS: Can't find a valid FAT filesystem on dev mmcblk1.
[ 21.571044] FAT: bogus number of reserved sectors
[ 21.575958] VFS: Can't find a valid FAT filesystem on dev mmcblk0.
[ 21.960845] FAT: bogus number of reserved sectors
[ 21.965637] VFS: Can't find a valid FAT filesystem on dev mmcblk0.
[ 22.007354] FAT: bogus number of reserved sectors
[ 22.012176] VFS: Can't find a valid FAT filesystem on dev mmcblk1.
[ 22.178680] UBIFS: mounted UBI device 1, volume 0, name "boot"
[ 22.184631] UBIFS: file system size: 8386560 bytes (8190 KiB, 7 MiB, 65 LEBs)
[ 22.192016] UBIFS: journal size: 1032193 bytes (1008 KiB, 0 MiB, 6 LEBs)
[ 22.199310] UBIFS: media format: w4/r0 (latest is w4/r0)
[ 22.205169] UBIFS: default compressor: lzo
[ 22.209320] UBIFS: reserved for root: 396117 bytes (386 KiB)
[ 22.699432] mmci-omap mmci-omap.0: MMC IRQ 0x208000 : ERRI DCRC
[ 22.701629] mmcblk0: retrying using single block read
[ 23.605041] dpll1_ck rate: 600000000
[ 23.608734] arm_fck rate: 600000000
[ 23.612365] PLL_MPU rate: 600000000
[ 23.675964] input: nub0 as /devices/platform/i2c_omap.3/i2c-adapter/i2c-3/3-0066/input/input6
[ 23.925964] input: nub1 as /devices/platform/i2c_omap.3/i2c-adapter/i2c-3/3-0067/input/input7
[ 71.802459] aufs test_add:243:mount[1208]: uid/gid/perm /mnt/pnd/op_wifi 1000/1000/0755, 0/0/0777
[ 72.680053] Generic kernel compatibility enabled based on linux-next next-20100113
[ 72.992675] cfg80211: Calling CRDA to update world regulatory domain
[ 73.742858] lib80211: common routines for IEEE802.11 drivers
[ 73.748748] lib80211_crypt: registered algorithm 'NULL'
[ 73.776763] lib80211_crypt: registered algorithm 'TKIP'
[ 73.803253] lib80211_crypt: registered algorithm 'WEP'
[ 73.829986] lib80211_crypt: registered algorithm 'CCMP'
[ 73.945465] Pandora WiFi: Probe started
[ 73.972167] Sending insert event for MMC3...
[ 73.976470] Pandora WiFi: Probe done
[ 74.026214] mmc2: card claims to support voltages below the defined range. These will be ignored.
[ 74.035186] mmc2: SDIO card claims to support the incompletely defined 'low voltage range'. This will be ignored.
[ 74.058166] mmc2: new SDIO card at address 0001
[ 74.152191] wl1251: using dedicated interrupt line
[ 74.497650] phy0: Selected rate control algorithm 'minstrel'
[ 74.498443] wl1251: loaded
[ 74.501190] wl1251: initialized
[ 75.901885] sdio_reset_comm():
[ 75.917785] wl1251_sdio mmc2:0001:1: firmware: requesting wl1251-fw.bin
[ 78.468109] wl1251: ERROR timeout waiting for the hardware to complete initialization
[ 93.855041] sdio_reset_comm():
[ 95.650177] wl1251: ERROR timeout waiting for the hardware to complete initialization
[ 95.714630] sdio_reset_comm():
[ 97.500793] wl1251: ERROR timeout waiting for the hardware to complete initialization
[ 120.358673] aufs test_add:243:mount[1551]: uid/gid/perm /mnt/pnd/op_wifi 1000/1000/0755, 0/0/0777
[ 120.651733] Pandora WiFi: Remove started
[ 120.651733] Sending remove event for MMC3...
[ 120.683288] Pandora WiFi: Remove finished
[ 120.826873] wl1251: unloaded
[ 120.870971] mmc2: card 0001 removed
