Drak
fff
When i try to remove voice streams from a audio file i got i fail. Any1 know how to keep the background music in a mp3, without the volcals in it? Like they do on American Idol.
markusdragon posted on May 2 2005 at 01:07 PM said:It's possible on some tracks, but only because they place the vocals on both the left and right channels, so you just have to remove the stereo'd vocals.
Try goldwave. Some files i've ran through it's vocal remover have had some margin of success. Otherwise you'll need an instrumental version of the song (which is what they actuallly do on Simon Cowell's many and completely identical tv shows)
Mosch posted on May 2 2005 at 01:21 PM said:Um... it's not that hard, depending on the quality you want. I did it with CoolEdit Pro 2.0 several times. I don't think you can buy the program anymore though, and searching it via eDonkey, then downloading, would of course be illegal, so don't do it. Eventhough there is a working version with serial and crack available. Still illegal. Don't do it. Yadda.
Wow markusdragon you're an eternal fountain of information!markusdragon posted on May 2 2005 at 09:07 PM said:It's possible on some tracks, but only because they place the vocals on both the left and right channels, so you just have to remove the stereo'd vocals.
