velvetfr
Hi all,
I am confronted against a problem on GP32 when trying to disable and enable the video output through the ENVID bit of the LCDCON1 register. When setting the bit to 0, the output is disabled, and apparently it is working (the screen is like frozen, which is normal), but when putting back this bit to 1, the screen is then re-enabled but seems to have like a refresh problem (a lot of disturbances are occuring on the screen).
Is someone has already expereinced that, or someone have the solution around that problem ?
Thanks in advance,
velvetfr
Thanks in advance,
velvetfr
