avi sound problem
is there a way to make the sound higher on moviepark or a way to make it higher before i put it on my gp32. i got ghost in the shell but the sounds so low i can barely hear it. could it be my batteries or is there a way to make it higher?
I had that problem too, and where it says volume in "Sound" (I think), just put the volume to 300% or something. It seems to work for me, maybe for you too.
On VirtaulDub, under the Audio heading, select Volume, and increase it to as much as you'd like. I personally don't know if it works, because when I did it I had not previously listened to the avi file, but I had listened to others so I increased the volume. I think it worked, but maybe the avi file I used just happened to be a bit louder than the others. Good luck, and keep asking if you need more help. I will continue to look at this topic. ;)
What version do you have? I use VirtualDub 1.4.13 Go to the top and click on Audio, scroll down and click on volume. If you have a different version I don't know what to tell you, but it is on mine. I will get on later if you have more questions. Oh yeah, don't forget to click on Full processing mode under the audio heading, just in case volume does not appear.
