I first upaded from 1.10 to 1.2.0 but I was using the pulsar skin and we all know now the problems with 1.2.0 and custom skins so I downloaded and installed the default skin from the archive. Then I tryed to down grade to 1.10 however it did not do it, in fact when I start the GP2X with the files on my SD card it actually deletes the .img file? I then used that program to downgrade to 1.1.0 and that worked but then I tryed to upgrade to 1.2.0 again I have the same problem, it won't upgrade and actaully deletes the .img file. I don't think it is an SD card issue as I tryed it with three SD cards and all these cards work fine when running stuff on the GP2X
This means that I cannot upgrade my GP2X sooooooooooo Help
