shoulder button broken - where to get spare parts?
ashcloud
-- BANNED! -- Lactose Intolerant Volcano
guru.awakes.dormant
Hi there,
some block of cobblestone hit my Pandora directly on the right sholder button. The button got torn off the board and was totally destroyed (The SMD part, NOT the plastic case). Fortunatly the solder pad seems to be fine. I could solder that myself, but I'm wondering which part to get and where to get it from. Everything else is working just fine. The case got a little crack, but thats a minor issue.
i had a similar issue, my pandora hit the ground directly on its left shoulder button. The SMD lost the contact to the PCB. As i tried to fix it the SMD disasembled in a few parts: A golden small plate the button itself and a 'cases' for the golden plate. To cut it short my father was luckily able  to replase the original part with a reset button from an outdated router :D
The original button SMD falls easily in its parts, yout could also try to replace the original one with some spare sparts ^ ^
good luck !
B)
