Need A Little Help With Usb Networking
dnlgreenwood
I'LL END YOU!!!
BC, Canada
Well, I've finally figured out how to connect my Caanoo to the Internet through USB networking! Well, almost. I can ping any internal or external IP address, apart from my Linux PC, from my Caanoo, but I cannot access any web pages, FTP servers (even ones on my local network), IRC servers, or Quake servers.
This is how I've connected it:
1-Connect the Caanoo to Linux PC via USB cable
2-Start the USBnet program
3-PC automatically detects the Caanoo and connects to it
4-Open Firstarter (firewall manager)
5-Set eth0 (PC's ethernet adapter) as internet connected network device
6-Set eth1 (PC's WLAN adapter) as local network connected device
7-Firewall starts and Caanoo is now connected to the rest of my network and the internet through my PC
When I try to ping anything at all, except for my Linux PC, I get a response, usually a 0% packet loss. However, when I try to connect to something, like a webpage though Links2, for example, it fails.
Error loading http://gp32x.de/:
Host not found
Also, when I run
wget http://www.google.ca
I get this error:
Connecting to www.google.ca
wget: bad address 'www.gp32x.ca'
However, if I stop the firewall, I get a different error:
Connecting to www.google.ca (72.14.213.105:80)
wget: cannot connect to remote host (72.14.213.105): Connection timed out
I've tried setting it as a DMZ host in my router's management console, (not protected by the router's firewall; directly connected to the Internet) but that didn't work.
For some reason, I cannot connect to the SSH server on my Caanoo from my PC after step 7 (above).
Yeah, I can't ping my Linux PC though 192.168.1.64 (WLAN) or 192.168.1.66 (ethernet) or 10.0.0.1 (USBnet) after step 7 (above). However, I can ping any of those addresses before step 7 or if I stop the firewall. However, if I stop the firewall, my connection to everything else stops as well.
In case it matters:
ifconfig -a of my PC:
eth0      Link encap:Ethernet  HWaddr 00:26:55:c3:0d:59
          inet addr:192.168.1.64  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::226:55ff:fec3:d59/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:14718 errors:0 dropped:0 overruns:0 frame:0
          TX packets:3831 errors:0 dropped:0 overruns:0 carrier:1
          collisions:0 txqueuelen:1000
          RX bytes:2518076 (2.5 MB)  TX bytes:395055 (395.0 KB)
          Interrupt:43
eth1      Link encap:Ethernet  HWaddr 00:26:5e:8b:3c:f9
          inet addr:192.168.1.66  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::226:5eff:fe8b:3cf9/64 Scope:Link
          RX packets:10580 errors:0 dropped:0 overruns:0 frame:851
          TX packets:19 errors:16 dropped:0 overruns:0 carrier:0
          RX bytes:667901 (667.9 KB)  TX bytes:4745 (4.7 KB)
          Interrupt:16 Base address:0xc000
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:24 errors:0 dropped:0 overruns:0 frame:0
          TX packets:24 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:1440 (1.4 KB)  TX bytes:1440 (1.4 KB)
usb0      Link encap:Ethernet  HWaddr ea:82:63:08:ab:ec
          inet addr:10.0.0.1  Bcast:10.0.0.255  Mask:255.255.255.0
          inet6 addr: fe80::e882:63ff:fe08:abec/64 Scope:Link
          RX packets:555 errors:0 dropped:0 overruns:0 frame:0
          TX packets:531 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:42410 (42.4 KB)  TX bytes:48813 (48.8 KB)
ifconfig -a of my Caanoo:
          RX packets:14 errors:0 dropped:0 overruns:0 frame:0
          TX packets:14 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:996 (996.0 B)  TX bytes:996 (996.0 B)
usb0      Link encap:Ethernet  HWaddr 06:E5:9A:07:B0:C4
          inet addr:10.0.0.2  Bcast:10.0.0.255  Mask:255.255.255.0
          RX packets:532 errors:0 dropped:0 overruns:0 frame:0
          TX packets:560 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:41407 (40.4 KiB)  TX bytes:50514 (49.3 KiB)
