It's Going To Be Easy To Add A Digital Audio Output (spdif)?
timofonic
GP Mafia
Hello.
I would like to know if there will be some easy to access solder pad for the digital audio output of the system. Probably it will be possible to add it anyway, but it's better to have some solder pad that makes the task a lot easier.
I see there are solder pads for UART and others, but don't know about this particular thing.
I used the search function and not found a post answering this, sorry if I didn't find enough.
Regards.
