Are audio components the same in CC and GC Pandoras?
Discussion in 'Ask EvilDragon Questions' started by BaDToaD, Aug 22, 2012.
  1. BaDToaD
    BaDToaD "Very" Old Timer
    Jan 31, 2004
    2,452
    UK
    The above is very important to me for two reasons.
    1. I am contemplating upgrading my original CC Pandora to either a rebirth or 1GHz Pandora but I won't do this if the Audio isn't as good as the original CC Pandora. My Pandora blows all other portable devices I own out of the water for Audio and I don't want to part with that quality.
    2. I'm a moderator on a headphone forum and I want to review the Pandora on there and possibly get you a few sales but I don't want to do that if the hardware can't produce the same awesome sound as my CC Pandora.
    So in a nutshell. Do the new GC Pandoras sound as good as the old CC ones with decent headphones, not ibuds ;)
    Tags:
  2. EvilDragon
    EvilDragon Administrator Staff Member
    Mar 4, 2003
    19,575
    Ingolstadt
    Yes, we only made things better on the PCB, nothing worse :)
  3. peelie
    peelie Member
    Apr 6, 2007
    887
    how about the volume wheel? meaning have the 'crackly'' noise , (due to dodgy solder?) been addressed?
  4. ekianjo
    ekianjo Hardcore Member
    May 7, 2012
    8,261
    神戸市、日本 (Japan)
    Question : I have a USB to optical audio cable converter - would that work on Pandora too ? Or would specific drivers be needed, not included in the current firmware ?
  5. EvilDragon
    Mar 4, 2003
    19,575
    Ingolstadt
    If you've got crackly noise, it's probably a broken wheel...
    Uh... don't know, I guess notaz could answer this.
  6. mcobit
    mcobit Advanced Member
    Jul 28, 2008
    6,755
    Most external audiocards should work afaik. May need a hub though.
  7. the_marshal
    the_marshal Member
    Aug 27, 2010
    190
    I've got an original CC Pandora and don't have a problem with the volume wheel. I definitely agree the sound coming out of Pandora is awesome :)
    And you can drive a real headphone with it. With pretty much any other device you would need a portable headphone amp to get similar result.
  8. peelie
    peelie Member
    Apr 6, 2007
    887
    it's that issue where occassionaly when u turn the volume wheel there is a crackly noise, there is no noise once u stop turning. i think u mentioned once that this was due to solder issues on the volume wheel?
  9. mcobit
    Jul 28, 2008
    6,755
    Iirc some volume wheels were even deformed because of too much heat while soldering but that all should be history by now.
  10. peelie
    peelie Member
    Apr 6, 2007
    887
    hopefully ED can tell us if that is the case that this issue is no more
  11. TrashyMG
    TrashyMG Sarcasm Dispenser Staff Member
    Jan 18, 2010
    10,393
    Well since OPT moved production from the high failure rate board company in Texas (Circuit Co) to the Germany company this shouldn't be an issue any more.
  12. notaz
    notaz Certified Guru
    Aug 23, 2005
    4,911
    Lithuania
    There could also be dust in it, opening the case and blowing it out might help.
  13. EvilDragon
    Mar 4, 2003
    19,575
    Ingolstadt
    I also had success spraying contact cleaner into it.
  14. Esn
    Esn (:";
    Mar 5, 2003
    3,239
    Toronto, Canada
    I added the "volume wheel crackles" defect to the Pandorawiki's "Hardware defects" article:
    http://pandorawiki.org/Hardware_defects
    I have this issue as well (among a host of others... to be honest, I was planning to send in my Pandora for RMAing long ago but have had intermittent issues with my main computer so I needed to have a backup computer around)
  15. peelie
    peelie Member
    Apr 6, 2007
    887
    sweet the contact cleaner fix certainly improves this issue :)
  16. Esn
    Esn (:";
    Mar 5, 2003
    3,239
    Toronto, Canada
    P.S. ED, if you're reading this, please read the PM I sent you a little while ago. There are serious spam problems on the Pandorawiki that will only be solved by making it more difficult to register an account.
Share This Page
Loading...
