1942 Problems :'(
e_b
stops/freezes when you finish a level or lose all your lives (it's the bit where usually the score/stats would appear on the screen - they don't it just 'freezes')
I've tried 2 different sets of sets (6 different starts in total) and all exactly the same :(
any ideas?
anyone know this works...or has the same probs?
other than that I've had no probs with MAME on GP32 :unsure:
any ideas?
My advice.. Don't bother with MAME for this particular game. Use gpEngine instead and play the PCE version. It is just as good as the arcade version..
trooper posted on Mar 11 2005 at 10:33 AM said:
Have you tried using a lower clock speed.
Trooper
is yours working then?
I will try that, I was running it at 150Mhz and it always freezes at the same point...but the point is only either:
a) when you land on the carrier at the end of level 1
B) when you lose your last life
which is why I didn't think it was an overheating issue...unless producing the text on screen (which displays the stats) pushes it over the edge!? lol
as for PCE, that only has 1943 - which is not the same (for me anyway)
no luck at lower speeds :(
can no-one confirm if theirs works beyond my problems?
